Perform the following tasks to log in to the
      switch.
        The initial login prompt appears as
follows:
(Pending-AAA) login:
        At this point, the failsafe account is now
          available, but the normal AAA login security is not. (For additional information on using
          the failsafe account, refer to
Failsafe Accounts.)
        Wait for the following message to appear:
                    Authentication Service (AAA) on the master node is
          now available for login.
        At this point, the normal AAA login security is
          available.
        Press [Enter].
Whether or not you press
[Enter], after you see the
          logon prompt, you can perform a normal logon. (See
Default Accounts.)
        The following prompt appears:
            login
    After you have successfully logged on, the following information about
      successful and unsuccessful logons
      appears:There have been 26 successful logins since last reboot and 0 failed logins since last successful login
Last Successful Login was on: Thu Apr 23 17:16:08 2020
